Hello everybody! Please tell me how you can cut the surface to choose one or the other?
What could be the reason?
Can this be sorted?
I will be glad for any help
internalise.gh (15.6 KB)
Can this be sorted?
When I tried to look at your Rhino file, it looked different than what you have shown. Maybe I did something wrong.
But, I think you can do what you want using List Item. That will give you one of the fragments that was the result of the split. I would like to know how to specify which fragment though instead of testing different indices.
Yes? I’ve tried different approaches, but so far it doesn’t work (
This is what I mean:
I believe the problem is that SrfSplit needs surfaces as inputs. You have joined the base surface and the funnels into a polysurface.
If you create a parallel path for each of your surfaces (funnels and base surface) you can use those as inputs to SrfSplit and join them together after splitting.
I don’t know what sorting criteria you want to use. Possibly Point In Trim (TrimInc) might be useful if you can identify your pieces based on their containing a point or its projection.
Thank you!
