i’m trying to split this surface with lines the first split works but the second seems does not works for me, rhino crash, what other method could works in this case?
Why is this file so enormous?
to be honest I have no idea even is bigger than the full script.
I’m able to go through your entire process and it looks like you end up with all the triangular panels you want. (766). At what point do you crash?
in the second split aka “Result 2”
If you’re able to splitr with just one curve witjhout crashing, then maybe you could put the split in an Anemone loop. It takes a while but might help.
I made it in rhino I dont use anemone but im going toke a look! thank you!
