Split SubD with isocurve >>NEW<<
In case you missed it ( I did and I work here…)
you can now split a subd by isocurve using the split tool with the new edge loop option!
note the sharp corners yes/no option once you get into the command. if you mess it up you can use crease/ remove crease to fix it.
Great news :slight_smile: IMHO this SPLIT functionality should be also present here
Not related but a right click on the Reflect icon to remove reflect should trigger a different dialogue in the command bar instead of the normal reflect dialogue
Cheers
agreed on both counts.
I know reflect is getting a tuneup this is likely going to be part of that.
https://mcneel.myjetbrains.com/youtrack/issue/RH-64042
https://mcneel.myjetbrains.com/youtrack/issue/RH-64043
RH-64042 is fixed in the latest Rhino 7 Service Release Candidate
