I tried to script in python a split pointcloud option by using a minimum and maximum box coordinate.
In comparison with the standard rhino remove from pointcloud option it is very slow.
Is there a way to use this command in a python script? or is there another way in python to split a big pointcloud. The size of the pointcloud is 21102488 points.
In my opinion it is the best to go one time through the whole pointcloud with a list of box coordinates and than to replace and add the new pointclouds at ones.
import Rhino
import copy
import scriptcontext as sc
def DeletePointCloudPoints(cloud, minpt, maxpt):
cloud=rs.coercegeometry(cloud)
pts = Rhino.Collections.Point3dList(cloud.GetPoints())
pln = Rhino.Geometry.Plane.WorldXY
pln.Origin = Rhino.Geometry.Point3d(rs.coerce3dpoint(minpt))
r3d = Rhino.Geometry.Rectangle3d(pln, maxpt[0]-minpt[0],maxpt[1]-minpt[1])
pci = Rhino.Geometry.PointContainment.Inside
idx=[]
idy=[]
for i,pt in enumerate(pts):
if r3d.Contains(pt) == pci:idx.append(i)
else: idy.append(i)
idx = [i for i, pt in enumerate(pts) if r3d.Contains(pt) == pci]
if idx.Count > 0:
cloud1=copy.deepcopy(cloud)
cloud.RemoveRange(idx)
cloud1.RemoveRange(idy)
return cloud,cloud1
cloud=rs.GetObject('cloud',3)
minpt=[153758,-23000,0]
maxpt=[154758,5000,0]
cloudoud,cloudnew=DeletePointCloudPoints(cloud,minpt,maxpt)
sc.doc.ActiveDoc.Objects.AddPointCloud(cloudnew)
sc.doc.ActiveDoc.Objects.Replace(cloud,cloudoud)
sc.doc.Views.Redraw()
