Split or dispath list by elements area
Hello dear community,
I’m use Grasshopper with ARCHICAD connection. So I cannot internalise data in my definition.
Anyway you can check it.
Tiles generator v2.gh (34.4 KB)
It is tiles generator. Screenshot bellow
It works well. As you can see I use two tiles format: square (30x30cm) and rectangle (30x60cm).
Now I have control over all tiles. But I want to control 30x60 format separately.
In other words I want to select all 30x60 tiles.
As you can see final node is Region Intersection
Node result is Polyline curves as list
I want to select all polylines with area >=171369 sq.mm
I think I should use Split list or Dispath node…
But I don’t know how to make it. Hope you help me.
Thanks
Sorry, I don’t buy that. You can certainly internalize the rectangles you want to dispatch for the purpose of posting a question, then integrate the response into your proprietary project.
dispatch_2019Nov5a.gh (12.8 KB)
That can be done with internalized rectangles like this:
dispatch_2019Nov5b
dispatch_2019Nov5b.gh (6.8 KB)
Thanks so much! It works well!
