Split List Based on True False
I would like to ask how I might split this list of 1,815 TRUE and FALSE values into two separate lists. One for all the TRUE values and one for all the FALSE, while maintaining their item number.
Instead of scrolling through the list and trying to catch the TRUE values by “eye”, the goal is to quickly see if there are any TRUE values, and then with their specific item number, manually review the geometry.
I have not uploaded the definition as its quite large.
collision
Second guessing the recommended policy limits the help that anyone can provide.
Dispatch can separate the original geometry into two lists.
If I get you right… This:
Bul_Check.gh (8.0 KB)
Thank you for your time and for sharing your knowledge Joseph! I very much appreciate it.
I typically upload all my scripts when asking for help. On this occasion, i knew I was pushing my luck, but thank you all the same.
Thank you David for taking the time to help, I appreciate it!
Dispatch can also be used to separate the index values, if you must:
