Split failed with closed curve
I have been trying to split my polysurface with a closed curve that I named Split Curve. But when I do it says Split failed objects may not intersect or intersections may not split object. So, if anyone knows what to do in this situation, please help me out.
Split.3dm (46.9 KB)
Greetings,
Fosse
Hi Fosse - in this case the split curve is exactly on the joined edges of the object - rather than split, just Explode the object.
Thank you very much!
-Fosse
Is there a reason why it doesn’t mirror?
-Fosse
Hi Fosse - it is not clear what your action is but you do need to click to set the mirror axis end point.
That was it, I am pretty new to rhino so if came across a lot of issues but thank you for helping me out.
-Fosse
Hi Fosse - see
lots of good stuff there.
