I am trying to shatter curves by points in gpyhton script, however, the result shows
" Parameter must be a Guid or string representing a Guid."
I go through the lines find out the problem is at rs.SplitCurve. I did find some people on the forum have the similar issue with the Guid problem, but still i cannot resolve my error. Hope someone is able to provide a clue! Thanks in advanced!
the attachment is the GH file and following is the Gpython code.
Preformatted textimport rhinoscriptsyntax as rs
mesh = mesh
curves = curves
pts =
for i in range(len(curves)):
cmx = rs.CurveMeshIntersection(curves[i],mesh,False)
for j in range(len(cmx)):
pt = rs.AddPoint(cmx[j])
pts.append(pt)
newcurves =
for j in range(len(pts)):
if rs.IsPointOnCurve(curves[i],pts[j]) == True:
param = rs.CurveClosestPoint(curves[i],pts[j])
splitedCrv = rs.SplitCurve(curves[i],param)
newcurves.append(splitedCrv)
indent preformatted text by 4 spaces
mesh = mesh
curves = curves
pts = []
pts.append(pt)
newcurves = []
a = newcurves
If you’re using rhinoscriptsyntax functions, the type hint of the input has to be set to “ghdoc object when geometry”
rs.SplitCurve is a destructive operation, it modifies the original curve in-place and returns a list of splitted curves. So you have to make a copy of the original if you want to reuse it in your loop.
minor style tips: spot the edits below
mesh = mesh # not necessary
curves = curves #
pts = []
for curve in curves:
cmx = rs.CurveMeshIntersection(curve, mesh, False)
for x_pt in cmx:
pt = rs.AddPoint(x_pt)
pts.append(pt)
newcurves = []
for pt in pts:
if rs.IsPointOnCurve(curve, pt):
param = rs.CurveClosestPoint(curve, pt)
copied_curve = rs.CopyObject(curve)
splitted_curves = rs.SplitCurve(copied_curve, param)
newcurves.extend(splitted_curves)
a = newcurves
