Split Curves on curves
Hello I would like to split the set of Black curves on the set of White ones. So that as an Output I only get the set of splitted black curves.
Curve | Curve + Trim Tree + Shatter should work.
Post the file if you need more help.
It did work, thank you very much. Even though the Shatter component is red, but it gives the right output…
