Split brep
Hello, I have a problem using the Split Brep command. I would like the objects to cut to have “holes” where the intersection with the cutting object is, but the holes are not closed for some reason… in other words I would like to delete the holes created on the cutting object.
Thanks,
Madeleine
q_gh_split.gh (263.5 KB)
q_gh_split_re.gh (263.7 KB)
Is this what you want?..
Exactly, thank you!
Would you mind having a look at this? I just slightly changed the breps and now I dont get the same result…
Thanks!
q_gh_split_02.gh (265.5 KB)
q_gh_split_re02.gh (272.1 KB)
I think it’s best to do this…
That is working fine, but as soon as I change shapes to split or cutting objects it doesent work. Is there a more general solution? Attached is one example where I can not get your script to work…
q_gh_split_03.gh (571.2 KB)
q_gh_split_re03.gh (275.9 KB)
It’s complicated, but it’ll work exactly…
Thanks!
I have on last question (I promise), what if I would like to trim the beams with thoose small boxes (see screenshot).
q_gh_split_04.gh (204.6 KB)
q_gh_split_re04.gh (287.7 KB)
looking good but… why dont I get the same result? Do you know whats wrong with my brep?
q_gh_split_05.gh (293.0 KB)
q_gh_split_re05.gh (295.1 KB)
Check out what problems ‘BREP(B)’ has.
Wow, thanks! I dont know what you did but its working perfectly now! Thank you so much!
