minor issue, but i fail to understand why … and it cause some additional nodes to visualize the curves correctly
when I split some planar srf’s with a cone, I would expect the curve segments of the resulting trimmed surfaces to be a single curve, but it’s not. See attached image, to better illustrate the issue.
From the looks of it, at or near the isocurve of the cone the edge of the trimmed surface is split in two parts. split_behavior.gh (21.7 KB)
thanks inno, cheesy workaround are just part of life. Your suggestion made me abandon the cone, and make a ruled surface insteads (no point, but small circle at start location). That seems to get rid of the seam as well
