i am guessing I ll not be the only one with this happening to soon, its with bt so the biggest internet provider in the uk. Appols for all the trouble and thanks greatly to everyones help your all amazing. I ll see if there are different levels of protection from BT and try switching some off. But why it sees a connection to you guys at rhino as forbidden I ve no idea though… but theres a chain of pole dancing mens clubs called spearmint rhino here in the uk maybe its that link. r
@pascal - it would be nice perhaps to allow the user an option to suppress the feed. I didn’t post this as a request on youtrack, as there were so many items already related to the splash screen - so maybe it’s already there somewhere?
i can honestly say i ve had x3 sleepless nights worrying about it and to be honest I ve never even looked at the news feed at any point but I guess its of interest to others. So yes option to turn it off may well be a good option though I understand that its an old version of rhino now. I think My current solution is to look into the restriction on the internet service but I d like to still safeguard my kids as they are only 9 and are you tube addicted. Thanks again though for your help and for being great its very reassuring there’s people out there which eased my stress levels greatly.
I am looking into getting a new graphics card simply to get the more recent drivers on it so I can use my v6 rhino as currently it doesnt run thinking its a driver thing. The graphics current card doesn’t lag at all and works absolutely fine no mater what I throw at it however drivers update no longer available since 2016! My freeform software also is telling me the card limits certain aspects of that software also.
thanks. r
just an update really. I ve lifted the restrictions on my internet provider and all fires all fast now… thanks. r
Hi Robin - did you try setting up a shortcut with the /nosplash switch? Similar idea to the -stopwatch only instead of -stopwatch add /nosplash
I added a YT (@Helvetosaur) - better a duplicate then none…
i did that and worked great when opening fresh but I open probs 30 models as existing files per day so think the braodband lift of limitataions better option as works as before now so all good. I want to get my v6 rhino on the go really now. Need to add a new graphics card that I just had arrive today. I started a new thread for advice in fitting it! thanks, r
Hi Robin - @robin just fyi, there is the possibility of disabling internet action for Rhino altogether, with a scripted install:
https://wiki.mcneel.com/rhino/installingrhino/6
hiya,
I ve ordered a new pc for windows 10 pro.
the pc looks like this spec wise hope it runs okay!
Product
Total
1 x Cube Intel Home Office Desktop Series
£3,668.99
1 x No Antivirus / Internet Security is Required
£0.00
1 x 3 Year Collect and Return Warranty Service provided by MendIT (UK Only),Covers all parts, Labour and carriage costs for 3 Years,CR3-BOX3CR
£0.00
1 x Express 10 day Manufacture and Burn Testing
£0.00
1 x Cooler Master Cosmos C700M ARGB Tempered Glass Full Tower Case, Full Tower, Tempered Glass Side Panel, E-ATX | ATX | Micro-ATX | Mini-ITX, Radiator Support: 120/140/240/280/360/420mm, GPU Max Length: 490mm, CPU Cooler Height Limit: 198mm, Fans Included: 4 x 140mm, Fan Support: 120/140mm, USB Ports: 4 x USB 3.0 Type-A | 1 x USB 3.1 Type-C, Lighting: ARGB, MCC-C700M-MG5N-S00
£0.00
1 x Intel Core i9-9900X 9th Gen Processor, Socket 2066, Base Speed 3.5 Ghz | Max Speed 4.4 GHz, 10 Core (20 Threads), Cooling Not Included, Integrated Graphics Not Included, Compatible with X299 Motherboards, BX80673I99900X
£0.00
1 x HyperX Predator 32GB (2x 16GB) 3000MHz DDR4 RAM, Voltage: 1.35V, Latency Timing: CL15, Speed: 3000MHz (PC4-24000), 2 x 16GB DIMM Dual Channel Kit, , Intel XMP Profile Support, non-ECC Unbuffered Memory, HX430C15PB3K2/32
£0.00
£0.00
1 x PNY NVIDIA Quadro P2000 5GB Pro Graphics Card, NVIDIA Quadro P2000 Chipset, 5GB GDDR5 Memory Type, 4x Mini-DisplayPort | DisplayPort, Ultra-quiet active fansink, VCQP2000-PB
£0.00
1 x ASUS Intel Core-X STRIX X299-E GAMING ATX Motherboard, Intel X299, S 2066, DDR4, SATA3, Dual M.2, 3-Way SLi/CrossFire, GbE, WiFi, USB3.1 A+C, ATX, ROG STRIX X299-E Gaming
£0.00
1 x Samsung 970 EVO Plus 1TB M.2 2280 NVMe PCIe SSD, 1TB Capacity, PCIe 3.0 x4 NVMe 1.3 Interface, M.2 2280 Form Factor, Up To 3500MB/s Read | 3300MB/s Write Speeds, 5 Year Manufacturer Warranty, MZ-V7S1T0BW
£0.00
1 x Seagate 2TB FireCuda Desktop Hybrid Hard Drive (SSHD) 3.5" SATA III 6GB’s 7200RPM 64MB Cache, 2TB Capacity, 7200RPM Spin Speed, SATA III Interface, 8GB NAND Cache (Flash Memory), 3.5" Form Factor, Up to 5x faster than HDD,5 Year Warranty,ST2000DX002
£0.00
£0.00
1 x Cooler Master MasterLiquid Lite 120 All in one Liquid Cooler, High Density Sine Fine Design, 120mm Air Balance Fan Design, White LED Logo, Dual Dissipation Pump, Precision Machined Copper Plate, MLW-D12M-A20PW-R1
£0.00
1 x NZXT E-Series 850W 80 PLUS Gold Fully Modular PSU Power Supply, Wattage: 850W, Fully Modular, 80 PLUS Gold, 120mm Fan, CAM-Powered, Japanese Capacitor, 10 Years Warranty, NP-1PM-E850A-UK
£0.00
1 x Asus PCE-AC55BT Dual-Band Wireless-AC1200 Bluetooth 4.0 PCI-E Adapter,Wireless Standard: AC1200,Max Wireless Speed: 2.4Ghz:300Mbps/5Ghz:867Mbps,External antenna base,With Low Profile Bracket,Bluetooth 4.0,Wireless-AC dual-band for lag-free streaming and high performance network,High-speed wireless Internet connectivity,PCE-AC55BT
£0.00
1 x Windows 10 Pro Edition including 64 Bit Licence + Recovery Image
£0.00
1 x Microsoft Office Home & Student 2019 (Product Key Card), One-time Purchase, Product Key Card, Word | Excel | PowerPoint | OneNote, 1 User | 1 PC License, For Windows 10 or Mac OS, Home or Student use, 79G-05033
£0.00
1 x Cube Overclocking Service - Level 3,Up to 20% Increase in performance depending on MB / CPU and VGA Parts
£0.00
1 x Corsair ML 120/140 PRO Ultra Quiet Series - 1x Fan - Colour / Size to Suite Build
£0.00
1 x COLLECT - THIS CUSTOMER WANTS TO COLLECT!
£0.00
1 x Surcharge:0.46% Card Surcharge>>
£0.00
Total (Exc VAT) :
£3,057.49
£3,668.99
So i hope once running I can use all my software without issues! I am hoping that fresh pc and all latest gear will
make for a smooth running workflow.
hope alls well there?
thanks,
robin.
