No, actually that’s normal as you’re looking in the 32 bit Rhino V5 folder. Is that what you are using or is it the 64 bit version? The 32 bit version was named rhino4.exe for plug-in compatibility with Rhino V4 - that was necessary as Rhino V4 was also named rhino4.exe. But it’s not a problem.
If you are indeed using the 64 bit version of V5, then you are in the wrong folder. You need to look in Program Files, not Program Files (x86).
ah I found it. appols for being stupid on this stuff.
when i paste that in it goes like this… guess I am doing it wrong… pretty sure its the correct place though now which is a start. Being dyslexic doesnt help either. thanks,
Hi Robin - rename that to just Rhino.exe, then find a normal icon that starts Rhino, there is probably one on the desktop - right click on that and choose Properties:
Then start Rhino with that icon, and once started, hit F2 and copy paste all the info from that window here…
(4.7230) - Since Last Record = 0.0630 (%1.09) - - LoadToolBarFiles step 1
(4.7240) - Since Last Record = 0.0010 (%0.02) - - Start TryLoadRuiFile: C:\Users\pascal\AppData\Roaming\McNeel\Rhinoceros\6.0\UI\default.rui
(5.2050) - Since Last Record = 0.4810 (%8.29) - - END TryLoadRuiFile
(5.2050) - Since Last Record = 0.0000 (%0.00) - - LoadToolBarFiles step 2
(5.2420) - Since Last Record = 0.0370 (%0.64) - End of C# LoadToolBarFiles
(5.2420) - Since Last Record = 0.0000 (%0.00) - after m_pCallbacks->LoadToolBarFiles
(5.2420) - Since Last Record = 0.0000 (%0.00) - after RunLoadToolbars
(5.5260) - Since Last Record = 0.2840 (%4.90) - after RunPostLoadToolBarsAndRestoreDockBarPositionAndStates
(5.5260) - Since Last Record = 0.0000 (%0.00) - after LoadToolBarsAndRestoreDockBarPositionAndStates
(5.6170) - Since Last Record = 0.0910 (%1.57) - before Process Shell Commands
(5.7990) - Since Last Record = 0.1820 (%3.14) - after Process Shell Commands
(5.8010) - Since Last Record = 0.0020 (%0.03) - CRhStopWatch::ShowReport()
I do not recommend creating shortcuts with launch options because as @brian can explain they get deleted or do wierd things. I have a thread opened on this topic.
No, not quite. You need to find the desktop shortcut (make sure it’s the one for 64 bit), make a copy of it, and add the -stopwatch to that… then try running Rhino from that. Don’t rename Rhino.exe !
Loading Rhino Render, version 1.50, May 22 2017, 09:16:00
Error reading file: “C:\Users\Robin\AppData\Roaming\McNeel\Rhinoceros\5.0\UI\default.rui”
‘.’, hexadecimal value 0x00, is an invalid character. Line 125906, position 54.
(0.0000) - Since Last Record = 0.0000 (%0.00) - Create Stopwatch
(0.4700) - Since Last Record = 0.4700 (%0.45) - before CRhWGLExtensions::InitWGLExtensions()
(1.5790) - Since Last Record = 1.1090 (%1.06) - after CRhWGLExtensions::InitWGLExtensions()
(1.7220) - Since Last Record = 0.1430 (%0.14) - after create and load AppSettings
(1.7880) - Since Last Record = 0.0660 (%0.06) - Pre-initialize .net
(1.9620) - Since Last Record = 0.1740 (%0.17) - Post-initialize .net
(1.9760) - Since Last Record = 0.0140 (%0.01) - before Create splash window
(1.9760) - Since Last Record = 0.0000 (%0.00) - after Create splash window
(2.1650) - Since Last Record = 0.1890 (%0.18) - after load CMainFrame
(2.3840) - Since Last Record = 0.2190 (%0.21) - after initialize license mananger
(103.1890) - Since Last Record = 100.8050 (%96.02) - after loading of cursor resources
(103.4770) - Since Last Record = 0.2880 (%0.27) - after RegisterBuiltInCommands()
(103.5700) - Since Last Record = 0.0930 (%0.09) - Pre auto load plugins
(103.7630) - Since Last Record = 0.1930 (%0.18) - Rhino Toolbars and Menus
(103.7850) - Since Last Record = 0.0220 (%0.02) - RDK:CRhRdkRhinoPlugIn CTOR
(103.8050) - Since Last Record = 0.0200 (%0.02) - RDK:OnLoadPlugIn
(103.8080) - Since Last Record = 0.0030 (%0.00) - RDK:Initialize: after storage
(103.8300) - Since Last Record = 0.0220 (%0.02) - RDK:Initialize: after factories
(103.8310) - Since Last Record = 0.0010 (%0.00) - RDK:Initialize: after conduits
(103.8310) - Since Last Record = 0.0000 (%0.00) - RDK:Initialize: after default properties
(103.8320) - Since Last Record = 0.0010 (%0.00) - RDK:Initialize: end
(103.8320) - Since Last Record = 0.0000 (%0.00) - RDK:OnLoadPlugIn: after RDK Initialize
(103.8320) - Since Last Record = 0.0000 (%0.00) - RDK:OnLoadPlugIn: after RDK OnLoadRhinoPlugIn
(103.8390) - Since Last Record = 0.0070 (%0.01) - RDK:OnLoadPlugIn - end
(103.9290) - Since Last Record = 0.0900 (%0.09) - Renderer Development Kit
(103.9470) - Since Last Record = 0.0180 (%0.02) - Keyshot 5 Plugin
(103.9730) - Since Last Record = 0.0260 (%0.02) - 3Dconnexion 3D Mouse
(103.9730) - Since Last Record = 0.0000 (%0.00) - Post auto load plugins
(103.9980) - Since Last Record = 0.0250 (%0.02) - after create TabbedDockBarCollection
(104.0250) - Since Last Record = 0.0270 (%0.03) - after RestoreDockBarPositionAndStates
(104.0530) - Since Last Record = 0.0280 (%0.03) - Rhino Render
(104.0530) - Since Last Record = 0.0000 (%0.00) - after load default render engine
(104.0640) - Since Last Record = 0.0110 (%0.01) - after CloseAllDocuments
(104.1820) - Since Last Record = 0.1180 (%0.11) - before LoadToolBarsAndRestoreDockBarPositionAndStates
(104.1820) - Since Last Record = 0.0000 (%0.00) - after CRhUiWaitWhileDockBarManagerIsSaving
(104.1820) - Since Last Record = 0.0000 (%0.00) - after RunCreateWindowsMenus
(104.1860) - Since Last Record = 0.0040 (%0.00) - Start of C# LoadToolBarFiles
(104.2740) - Since Last Record = 0.0880 (%0.08) - - LoadToolBarFiles step 1
(104.4460) - Since Last Record = 0.1720 (%0.16) - - LoadToolBarFiles step 2
(104.5490) - Since Last Record = 0.1030 (%0.10) - End of C# LoadToolBarFiles
(104.5490) - Since Last Record = 0.0000 (%0.00) - after m_pCallbacks->LoadToolBarFiles
(104.5490) - Since Last Record = 0.0000 (%0.00) - after RunLoadToolbars
(104.5500) - Since Last Record = 0.0010 (%0.00) - after RunConvertToolbars
(104.7690) - Since Last Record = 0.2190 (%0.21) - after RunPostLoadToolBarsAndRestoreDockBarPositionAndStates
(104.7690) - Since Last Record = 0.0000 (%0.00) - after LoadToolBarsAndRestoreDockBarPositionAndStates
(104.7820) - Since Last Record = 0.0130 (%0.01) - before Process Shell Commands
(104.9720) - Since Last Record = 0.1900 (%0.18) - after Process Shell Commands
(104.9810) - Since Last Record = 0.0090 (%0.01) - CRhStopWatch::ShowReport()
Command: _CommandHistory
I hoping this means something to you guys… my tools paletes have all vanished though when it opened…!
Hi Robin thanks - - looks like the time is all here:
I’ll see what I can find out.
Meantime,
Try ToolbarReset and then restart Rhino - is that better?
Hi Robin - something to try, starting with Rhino closed:
Start RegEdit - Start menu > type ‘regedit’ and Enter, and say OK to the user account control message box.
Find this key:
HKEY_CURRENT_USER\Software\McNeel\Rhinoceros\5.0x64
Right click on this and choose ‘Rename’. Set the name to “5.0x64_X”
Start Rhino.
Is that any different?
If it is better, then please close Rhino, select the renamed key, and in the right click context menu, choose Export and zip and send us the result. If it is not better, please close Rhino. There will be a new key “5.0x64” in regedit. Select this key and delete it from the context menu, and then rename the old one back to “5.0x64” to restore things to how they were. There is another key we can try.
after opening and it not opening fast its pauses then flys open. dont understand the next part of what to do… cant seem to rename the folder back, cant find context menu not sure what that is?
Hi Robin - if there was no improvement, then in RegEdit right click on (to get the context menu) and delete the “5.0x64” key, then right click on the one renamed previously and choose Rename from the context menu that pops up from the right-click. Rename it back to “5.0x64”
Hi Robin - sorry for the messiness here - ToolbarReset and restart Rhino should get the toolbars sorted one more time. I’ll ask the bigger brains about the lag - so far we seem to be spinning our wheels.
its the internet… i disconnected and it flys open now… mybe something on parental control blocking whatever communication its trying to make? all that for days and something stupid
