No problem it is very similar to what I proposed in the other discussion.
First put the curves
Choose the number of spheres (1000 seems OK, 4000 points on my PC gives 5 min of calculations)
Toggle Kangaroo to TRUE, adapt the diameter if needed. If OK toggle to FALSE.
Choose an attractor point
Now you can open the DAM
Adapt the Graph Mapper in order to tweak the shape of the curve. As there is no dam double click on Graph Mapper to modify it.
You will need Kangaroo, Clipper, ShortestWalk. Human is not mandatory just to draw the lines so it is cool for the animation.
spiralize path Laurent Delrieu.gh (47.4 KB)
