There are two wavy lines. Is that intentional? If not then I think you have applied the wavy line to the straight line rather than the spiral. To make the flow work you have to:
- Select the wavy line in response to “Select objects to flow along a curve”.
- Select the straight line in response to “Base curve - select near one end”.
- Select the spiral in response to “Target curve - select near matching end”.
However, before you run _Flow, you need to extend your wavy line so that its beginning and end match the beginning and end of the straight, or base, line. As it stands the wavy line will only flow a short distance (its length) along the spiral.
Try that and let me know how it goes.
