Is there a simple way to penalise a surface into almost identical panels?
So penalisation is not following surface isocurves, but is vertical.
Test.gh (19.0 KB)
I think the process would be much easier if you had the complete loft without the spiral-trim
that way you could panel the entire loft as you desire, and then cull out the panels that don’t belong to the spiral portion of the surface
Thank you. Will try. Should work
