Spatial Deform Component Not Working?
Hi all,
Is the spatial deform component not working for Grasshopper in Rhino6?
I tried out the below script and the component throws the error ‘Object reference not set to an instance of an object.’ And tried it out in Rhino5, and it works fine.
SpatialDeformation (1).gh (11.8 KB)
Did you try Point Deform ?
http://rhino.github.io/components/transform/pointDeform.html
Did you look also here ?
thanks! wasn’t aware there was a point deform component; also didn’t know i could manipulate, in components and without code, the control points of a geometry besides curves.
An example here, surely a lot of, can’t open GH at the moment
