I didn’t try with Nesting tools but I do it with Wordle tool, it must be the same. Perhaps grouping could help. With Sparrow at them moment the important thing is to have just one closed curve per object.
nesting 2d silhouettes is easy. What is even the point in mentioning that as 3d nesing? That is incorrect name for it.
Real 3d nesting is 3d parts into 3d shape. Like Spectral Nesting paper released a few years ago.
https://dl.acm.org/doi/10.1145/3592126
Or this one from 5 years ago
I am nesting furniture parts into sheets. After the 3D parts are nested on the sheets I do extract the mechanization features from them. Something like this, but using 3D parts:
Here the workflow is the other way around. First was extracted the cutting features and after that the 2D paths was nested into sheets.
Hi @inno,
many thanks for your feedback and also kind words!
i’ve been actively using / testing this for the last few days, and in my experience changing seed is much more effective than increasing timeout! so with the new update there is an option to input multiple seeds (or just one) - it will return the best result out of those few seeds - and shows which seed was used.
since each run is on a separate process, testing a few seeds in parallel is possible with the same time.
also fixed this issue ![]()
i installed the sparrow 2.4 from the package Manager
i cant find the components in the tab or search
where can i find the component
I’m not quite sure why! i have tested on a few computers and the installation from package manager works. the component you could search for is spNest. alternatively you can try installing from github.
in my Windows 11 - Rhino 8 there’s a new GH tab called Sparrow with the 2 sparrow components
they noth pop-up when I type “sparr” in the search
it worked when i copied the files to libraries but not working when installed form package manager
it works like charm
