I get data output with “span tag” cause I cant get data outputs with input tag…
so I cant send datas to mysql database… How can I do that?
- I can get data with any other “tag” method?
- I can put span tag inside a input tag or something?
- I can send span tag to my sql?
Those are the solutions I can think…
Can you lead me to the solution pls?
Thx…
By the way mysql insert into with ajax and jquery…
I solved the problem as below :
<input type="text" id="deneme" value=""><span style="display:block;" id="ray_olcusu">
<td colspan="12"> <button class="btn btn-danger btn-block" onclick="getData1();">
İMALAT ÖLÇÜLERİNİ ÇIKART
</button></td>
<script>
function getData1() {
var res = api.scene.getData({name: 'ray_olcusu'});
document.getElementById('ray_olcusu').innerHTML=res.data[0].data
document.getElementById("deneme").value = document.getElementById("ray_olcusu").textContent;
</script>
with that way I get value from api.scen to span tag than put that span tag into the input value and so now I can easly insert into the mysql database.
