Spacing or Padding between icons in Panels are not consistent
Spacing or Padding between icons in Panels are not consistent in Rhino 9 BETA 15-09-2026 (Win).
I would prefer if the spacing was consistent in Collapsed mode and Expanded mode, and ideally that the user could choose a number for the Spacing or Padding, similar to the distance between Buttons. This is a normal amount of Panels in the RightContainer for a laptop running 1920 x 1080 px. When you collapse the RightContainer the spacing between the icons changes a lot.
PS. At least one icon “Snapshot” has a different look between Collapsed and Expanded Mode…
< > < >Rhino_9_WIP_Panels+Collapsed_Cropped
Addendum: The size of the icons in the Panels are different from the size of the Buttons and Tabs. The smaller icons inside the Panels, such as Layers and Layouts are limited to only 24 - Why?
I don’t want them to be bigger than the default button size. But if you have good reasons for them to be bigger, I can reconsider. For me 20 is the sweet spot, and 24 is already very large, making many panels wrap their icons to two rows.
I don’t see that in your screenshot, nor in my own Rhino install.
I no longer see two different icons for Snapshot i the Panel, when collapsed and expanded. I still see a different spacing between the Panel-icons, which amounts to one or two icons being hidded when in expanded mode compared to collapsed. The issue was the same in Rhino 8, but in 8 we did not have the “spacing and padding”-options in Toolbars, so maybe it could be solved now in Rhino 9?
I know this is an extreme example, but if you expect the users to actually understand the icons and not just use keyboard shortcuts, it must be possible to make a demo using maybe 48-64 px icons. If you are working on a Retina display or 4K and create a YouTube-tutorial you are missing a lot now.
I would prefer if it could be possible to change the size of ALL icons (or most of them) from 24-64 px.
In Rhino 8 the spacing of the icons in the Tabs are only changed for some of the Tabs and not all of them, when you during a Rhino session change from fx 24 to 48px, you are getting results like this. Some of the Tabs will have extremely wide spacing between the icons after the change, others not.
GUI_Rhino_8_Standard_46_pkt
GUI_Rhino_8_RenderTools_46_pkt
GUI_Rhino_8_RenderTools_32_pkt_WideSpacing
GUI_Rhino_8_NewIn_8_46_pkt
These issues with size not refreshing should not be happening in Rhino Beta.
Currently the icons in properties are fixed size tabs. That was another reason for me to limit the icons in tabs to 24.
These sizes are logical pixel sizes, so independent of chosen monitor resolution.
If you make a tutorial then I suppose you will not use some greatly altered Rhino setup.
