Is it possible to wrap long spacenames into several lines?
I am using it for text, because normal text is exploded into lines in the planviews - any better solution for this problem?
Btw - Same goes for dimensions, measured in the 3D model. In 2D view they are broken to lines.
It is not possible but you can use the “Description” property to write your text in a different line. You can also add custom parameters using the syntax:
@user28 I let you know we have added the option to generate texts as texts in 2D plan and section views (and not as 2D curves) recently in VisualARQ 3.3 Update - VisualARQ
