SpaceMouse = unknown command
Using Windows 11 with Rhino9 Beta.
Typing, SpaceMouse I get;
Unknown command
The plugin might not be loaded. And check the other topics….
pluginmanager shows 3DxRhino9 is loaded and enabled..
3DConnexion drivers 10.9.14 are installed.
My SpaceMouse is connected and working inside of Rhino as it should.
Typing, SpaceMouse = unknown command;
The SpaceMouse command is in the 3DConnexion 3D Mouse plugin (3DXRhino.rhp), not 3DxRhino.9.rhp, and only works in spaceball legacy mode, not the new beta mode. I don’t know if that is deliberate or accidental: it may be the intent is to use solely the 3DConnexxion app to control the settings - it now respects Rhino-specific settings in place of the standard 3DConnexion ones while running the beta.
You can toggle between legacy and beta modes in advanced options:
HTH
Jeremy
This makes sense
Yes, that’s correct. With 3DxRhino.9.rhp, the newer plugin, the intent is for the 3DConnexion driver to control the settings.
