SpaceMouse Rotation Direction Reverses
I am experiencing an issue with my 3Dconnexion SpaceMouse when using Rhino on my MacBook Pro.
My setup:
  • Computer: MacBook Pro
  • Virtualization software: Parallels Desktop
  • Operating system: Windows running in a virtual machine
  • 3D software: Rhinoceros 3D (Rhino for Windows)
  • 3D mouse: 3Dconnexion SpaceMouse
Description of the issue:
When I open a single Rhino session, the SpaceMouse works correctly, and the rotation direction matches my configured preferences.
However, when I open a second Rhino file in another Rhino instance and have both instances running simultaneously, the rotation direction reverses unexpectedly.
To restore the correct behavior, I have to:
  1. Close one of the Rhino instances.
  2. Open the 3Dconnexion application.
  3. Disable and re-enable the Reverse option.
  4. Resume working with Rhino.
After doing this, the SpaceMouse works correctly again.
The problem appears specifically when running two Rhino instances simultaneously. With only one instance open, everything works as expected.
My question:
Is this a known issue with the 3Dconnexion driver when running Rhino for Windows inside a Parallels Desktop virtual machine? Could this be related to how the driver handles application-specific profiles or multiple Rhino instances?
I would appreciate any suggestions for resolving this issue permanently, without having to toggle the Reverse setting every time I work with two Rhino files.
Thank you!
Is the 3Dconnexion driver installed inside the Windows virtual machine, with the SpaceMouse connected directly to Windows through Parallels, or is it also running on the macOS side? If both sides have the driver active, two sets of settings can end up applying to the same device, so it would help to know where the Reverse option you are toggling lives. It would also be useful to know whether the reversal affects every axis or only rotation, and which driver version is installed in Windows.
HI.
Thanks for your reply.
Its also running in macOS but I have to chose which OS I connect the peripheral, I believe I cant run on both at the same time. For instance if I have Rhino open on Windows and MacOS at the same time, the 3D Mouse wont work on both back to back. I have to disconect on OS to connect on the other one.
The rotatation toggled is the one turning off when I open the second rhino window. So I have to uncheck and check the box again. I have updated the driver many times and it keeps having the same issue.
