Space Truss Grasshopper
Hi, I am creating a double layer barrel vault shape space truss using grasshopper and lunchbox. However, when I connect the two surfaces of the barrel vault to the space truss operation in grasshopper, the generated lines between the two surface cross each other. It looks like its mapping to the corresponding node but on the opposite side as opposed to the ones directly above below / each other. Any thoughts?
Moved to Grasshopper category
I needed to flip the direction. It’s fixed.
