I currently have a 3DConnexion SpaceNavigator and when opening igs files in WIP6 it wll go right to “Creating Meshes” and will not let anything else happen until it finishes. Including shutting down the program other than Ctrl-Alt-Del. This didn’t happen in V5, so something changed in WIP6.
Is there any other space mouse out there that works with WIP6 and will not start meshing???
I also have filed a very similar issue in the past which is referenced in that report so hopefully the two of them can help the developers figure out what’s happening here and why. You need a really dense igs file to see it and usually those files are proprietary in my experience so I made a simple test procedure for the devs to reproduce it.
Something I noticed while testing this was that the igs import in the v6 WIP is 20x faster than in v5! So I found it still faster than v5 to just wait for the render mesh creation in the v6 WIP when the 3D connexion plugin is enabled… for what it’s worth.
Thanks for the comments and support with this issue. WIP6 has several things that are far superior to V5, but if I can’t use the tools that make my workflow faster I’m going backward.
Regards,
Goth02 2 Sm eMail
The Core - Gary R Fulkerson, CEO - 10185 Elizabeth Lake Road, White Lake, MI 48386 - 248 819 8052 - gary.core@comcast.net
Yeah, I read this and could not figure out how or where to do this with my mouse. There are very few controls available in its set-up app, and there is nothing in any menu that has “Rotation Center” in it.
Can this guy do a step-by-step of how to disable the Rotation Center?
Regards,
Goth02 2 Sm eMail
None of what you’re showing exists with my mouse. I have two options, one is the apps menu and the other is the menu button that is not what you are showing.
Apps options:
Screenshot (1)
Menu button on the mouse:
3D
Regards,
Goth02 2 Sm eMail
Are you clicking the settings/menu button on the navigator when in a Rhino viewport? This brings up the menu I showed in the last screenshot here. If that’s not working for you, check that the 3D connexion plugin is enabled in Options>Plugins within Rhino.
I’m not sure why you’re not getting the same settings menu. In the All plugins list, check the Properties of the 3D connexion plugin… This is what I get…
Have you tried running the SpaceMouse command and then clicking on “Popup_Menu” in the command line options? This brings up the same settings menu for me. If that doesn’t work either, I’d try emailing 3D Connexion using the email in the Plugin Properties to see if they know why you can’t see the popup menu for the navigator in Rhino.
I think the easiest way to solve this is for you to consider me an idiot about computer commands and give me step by step instruction like you would give a 90 year old man that’s never touched a computer before.
Example of my being an idiot is I don’t really know what you want me to do when you say to run the SpaceMouse command. If I right click on the Window logo in the lower left corner of my screen I can select “Run”, that’s what I tried with these instructions and I get the warning the Windows cannot find “SpaceMouse”. Other than thius I don’t know what you want me to do… I just saying…
Regards,
Goth02 2 Sm eMail
I opened a few files that before would go right into creating meshes, and they didn’t do so any more. It appears that you helped fix the issue. I’ll contact 3DConnexion and inform them of the fix.
Regards,
Goth02 2 Sm eMail
I stated to use the _SpaceMouse command because I also no longer see the popup menu in either V5 or V6. Also, the command macros in Rhino Options - 3Dconnexion Buttons no longer work. What version of the 3DxWare driver are you using? I’m using the latest, 10.4.10.
