The Schmitt-Conway-Danzer biprism: it fills space, but the pattern never repeats.
RhinoPolyhedra creates about 700 polyhedra in Rhino and Grasshopper, and a couple of dozen of them have a special property: they fill space. Stack identical copies and they fit together with no gaps and no overlaps, the 3D version of tiling a floor.
That turns out to be rare. The cube is the only Platonic solid that does it, and only a handful of polyhedra with regular faces manage it at all: the cube, the triangular and hexagonal prisms, the truncated octahedron and the gyrobifastigium. The rest of the list is a collection of oddballs, and that’s what makes it fun:
- Some show up in nature. The truncated octahedron is Kelvin’s 1887 answer to the most efficient foam. The rhombic dodecahedron is the cell you get from packing oranges (face-centered cubic) and a common shape for garnet crystals. The trapezo-rhombic dodecahedron is its hexagonal-packing twin.
- Some only fill space by translation. The five parallelohedra (cube, hexagonal prism, rhombic dodecahedron, elongated dodecahedron and truncated octahedron), plus Bilinski’s dodecahedron and Escher’s solid, never need to be rotated. Every copy points the same way.
- Some need several orientations. The bisymmetric and sphenoid hendecahedra, the ten-of-diamonds decahedron, the gyrobifastigium and the cross space filler only fit together as copies turned in several different directions.
- Some need their mirror image. The orthoscheme and the Hill tetrahedron are chiral: half the copies are left-handed and half right-handed.
- One never repeats. The Schmitt-Conway-Danzer biprism fills space, but each layer is turned by an irrational angle from the one below, so the pattern never comes back around. It’s an early 3D cousin of the 2D “hat” aperiodic monotile.
To show them off, I made a Rhino file for each one. Each file is a chunk of the tiling built from a single block, so the shape is stored once and every tile is an instance. Tiles are colored by orientation, so you can see how the pieces interlock. Every arrangement was checked numerically for gaps and overlaps.
Hover over or click an image to see its name; they’re in the same order as the table below.
All 25 shapes, by how they fill space:
| How copies fit | Shapes |
| Translation only | Cube, Hexagonal Prism, Truncated Octahedron, Rhombic Dodecahedron, Elongated Dodecahedron, Bilinski’s Dodecahedron, Escher’s Solid |
| Rotated copies | Triangular Prism, Gyrobifastigium, Elongated Gyrobifastigium, Trapezo-rhombic Dodecahedron, Triakis Truncated Tetrahedron, Hemicube, Tetragonal Disphenoid, Bisymmetric Hendecahedron, Elongated Bisymmetric Hendecahedron, Sphenoid Hendecahedron, Elongated Sphenoid Hendecahedron, Ten-of-Diamonds Decahedron, Cross Space Filler, Rhombic Dodecahemioctahedron, Elongated Square Dipyramid (space filling) |
| Mirror images needed | Orthoscheme, Hill Tetrahedron |
| Never repeats | Schmitt-Conway-Danzer Biprism |
RhinoPolyhedra is available from Rhino’s PackageManager. Look in the Space Filling Polyhedra category of the Polyhedron command, or use the Polyhedron component in Grasshopper.
All 25 .3dm files, if you want to take a closer look:
Space Filling Polyhedra.zip (1.3 MB)
Cheers,
– Dale
