Space Explorer
I have a 3DConnection Space Explorer. It works on Rh5 But I cant make it work in Rh6.
Is it possible to make it work in Rh6??
Best regards Stefan Törnblom
The 3dconnexion in the later Rhino 6 service releases needs a newer driver to work, I wouldn’t be surprised if your (discontinued) device isn’t supported by it. You’re probably best off poking the folks at 3dconnexion about this.
Ok I will do that
I am so used to work with the Space Explorer, it speeds up the work so much that I cant work without it.
