Hi!
I’m trying to select all the lines in each vertical column but the last item in the column is in the next column. Is there a way to sort and select them?
Sorting lines.gh (185.5 KB)
Hi!
I think it would be easier if you could post the part of the definition before the Shatter, probably also the earlier part starting from where curves are created in first place
