Hie,
i have a problem with sort dates. In the images, you can see the results sorted the same list. First, get it through a component and second with copy/paste in a Panel. With the first option “80” appear in 49th place but in the second apperars in the first place.
oh, i see what you mean. that’s because the two problematic panels are not lists, it’s a single string
to solve that, right click on the two panels and select multiline. but you’ll get an error since it expects the number of items in both lists to be identical
