Hello, please help. I would like to arrange the faces of breb based on the other faces
Anyone can help
Hi Ibrahim, Can you provide more detail in your question? Orient Component (Rhino Orient3pt command) will arrange geometry based on a plane - plane transformation.
Please read the suggestions on how to make it easier for others to help.
I want to sort faces of one geometry based on the another one
I try to make the faces the same index In tow objects
It seems unlikely that two meshes would have exactly the same faces.
If they are superimposed on each other, you could use ‘Closest Point’ to find the mesh face on one that is closest to the selected face on the other?
