Something like ShowZBuffer that shows normals of a scene?
Is there a command like ShowZBuffer that can show normals of a scene, similar to what ‘Geometry Normals’ in VRay does?
Thank you!
You can try _TestShowNormalMap
Since it’s a “secret” command, it does not autocomplete.
that’s kinda awesome, thanks! any other favorite hidden commands?
Oh cheers! This is exactly what I was looking for. Appreciate it
@Andrea, the command that Jarek mentioned affects rendered display mode - not shaded. Also in case it helps, the full render window has a provision for this - it needs to be enabled in the Rendering panel
then toggled as needed in the render window
