Something is not working well with 'perp'
Something strange with the 'perp' definition when working with a polyline. I definitely don't have a 3D object. This is what it looks like
 the point that shows 'perp' is not 90 degrees to the line . How can I fix this?
Perp means the point is perpendicular to the line you are hovering over, that line you are hovering over itself might not be perpendicular to the cplane
Thank you very much for the answer! (sorry, my English is not the best:)
The line I am hovering over is created from 'smarttrack' so I assume it must be with the axes of the Cplen
Sometimes I do move the Cplen according to a face of an object, and return it to the 'world' position
But this problem appeared long before I knew this option. And it also happens in files where I didn't move the Cplen at all
