cross select for sweep2rail. So to not select the two rails separately but with a cross selection.
osnap isolate. I have always have some osnaps selected, but sometimes I like to use one. I know this can be done for one time, but if have to copie several times only in the centre. It could be handy if the one time (alt) can be done with a on and off function to isolate an osnap.
one major improvement could be is a stroking function for surfaces. srfblend does this kind of but this is not always possible and not working all the time. Also when editing a blended surface (corner between two surfaces) the blend is not stroking automatically.
While working I come up for more things I think version 5 is missing.
Right-click the checkbox you want in the Osnap panel. That will turn on just the one you want and others off. When done, right-click on the same checkbox again and the previous active osnap collection will be restored. Works in V5.
Hey, since you working on new product, my idea to upgrade workflow in Rhino would be a search box in Layer tab. I’m always struggling with digging through thousand layers and it killing me. Best!
yes I know that, but it doesn’t speed up your workflow at all…It should me more like in Photoshop where searchbox is always on top and you can type single character/sign and it’s filtering list of layers up to date in order to that character
Thanks Pascal, Attached is one of the common situations I have to deal with. I have to do a new blend if I moved (upper control points moved) a part of the surface, like the last object showing. The blend is not stroking anymore.
There are more things like this, maybe this is just the way Rhino works. On rebuilding parts after a fast change of surfaces.
