- So, when You are rendering with Brazil, Rhino is blocked and no work can be done?
- There is no ‘‘Pause button’’ in the render window?
Yes and yes. So the best way to use Brazil is through Neon, which gives you a raytraced viewport that supports 90% of Brazil’s features(and is based on technology that will underpin the next version of Brazil,) most of the time you don’t have to actually fire up Brazil itself.
