i tried open nest to nest a stair but the stair string is not nested.
Any advise why this happen is welcome.
here are the reduce file.
nest_test.3dm (1009.6 KB)
nest_test.gh (147.4 KB)
Have you tried to increase the “Absolute Tolerance” Unit in Rhino?
if not, here is the address:
Tools>Option>Unit>Absolute Tolerance
try a very low number!
Thanks for helping i tried your advice but it didnt changed the behaviour of the nesting algorithm.
If the stair string gets rotated the algorithm works so i thought to increase the rotation value that the algorithm need more angles to check now it works.
