One one of my layouts, I have two adjacent detail viewports which should crop to isolated views of two parts of the same drawing.
When I go to the Save As/Print preview dialog, the details appear correctly. However, when I Save as .svg, the dashed lines and joined open curves extend past the detail crop boundary. The other open- and closed-curve lines and the hatches crop properly.
I tried putting a new viewport window showing a blank part of the drawing in the space in between, but the outcome is the same.
Hi Pascal, just wondering if any thoughts on this?
I tried using a viewport to a solid-fill hatch on the layout to cover the space in between the drawings, but the lines still showed up beyond the bounds of the detail box.
Should I assume that for now, the only way to assure proper cropping is to make a different layout for each detail, with the layout size the exact same size as the viewport detail?
