Some help to extract length
I need to move a collection of point with a different factor in z. In order to achieve that i have this collection of curves (created from the points i need to move) with different length to use this valor as a factor of movement for each different point.
The problem is when i try to extrat the length of curves
Captura%20de%20pantalla%20(21)
Without the flatten option its “imposible” extract the differents lenghts
For the deffinition its a trouble because after achieve the move transformation i need to join all curves as a boundary but the flatten option change the nature of the list items so its produce a fail in the next steps
Finally the vector to extrude does not work
Sorry the bad english :stuck_out_tongue:
Solved: I flatten all the curves
I’m not quite sure I understand your problem.
If you hover with your mouse over an input or output of a component that is using branches, you will not see what’s inside the branches but only the branch structure. If you plug in a “panel” you will see the content.
You can just use the output the same way without flattening anything.
