Some decals don't appear in render view, but when rendered, they do
I’ve attached two images here. One shows a Formula 1 race car with decals. Some of the decals that I’ve placed are not showing up in the render setting, however, when I render the image out, they do. Is this a bug or are there limits on how many decals can be shown at one time on a object. Just wondering if anyone else has run into this issue.
With what projection type are those missing decals placed?
oh, I see now. You’re not seeing them in the Rendered viewport. I initially read the other way around.
@DavidEranen do you know if there is a decal limit for Rendered mode?
Hi @Jim_Girard
Cool model! :flexed_biceps: I seem to remember running into something similar, where it was the format of the bitmap - might have been either bit depth, file format, colour space or something else entirely - I can’t recall. Try checking if those not showing share any similarities (or save them all as standard JPG’s).
HTH, Jakob
There is currently a 3 decal/bitmap limit in Rendered mode. Raytrace mode and normal raytrace does not have this limit.
