Some 2D hatches don´t export to dwg
I have a huge 2d landscape plan, with 1000 hatches. abot 60 of them just won´t make it to dwg (AutoCad). whatever I tried, they keep being skipped.
Rebuilding all of them is too time consuming. they are all on the same layer, but have different colours (that need to stay). All of them are solid hatches, so I really don´t get, what´s the issue here. Is it maybe connected to accuracy and units (tolerances) in the model?
Anyone has an idea? Or a gh file to simply fix it?
Any help would be much appreciated. Thanks in advance
I work with Rhino 8 on Windows.
Hi @Jan_We,
Can you share a file we can use to repeat the problem?
– Dale
i experienced the same problem in the past.
SelHatch → Explode fixed the problem, but you loose the information on hatches
I found a workaround. the borders of the missing hatches had to be duplicated, the curves needed to be simplified, and then hatched again. Worked for 90%.
Some hatches wouldn´t make it, when importing in Rhino as dwg.
Other Softwares (like BricsCad) were able to read the hatches from the dwg properly.
Interesting thing. Thanks for your support!
Hi @Jan_We,
We’d still appreciate a file - exporting to AutoCAD should work. Free free to send to me privately if needed,
Thanks,
– Dale
RH-99085 is fixed in Rhino 8 Service Release 37
Great. Thanks a lot!
