@anna_kiwi3d Just to confirm… the correct location for the carat.exe executable is AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\TeDAsharp... as shown above?
Yes, seems correct, if you used the installer. If you did it manually via Rhino Pluginmanager, it is the initial folder. In general, carat.exe has to be next to the TedaSharp_050.rhp file.
Do you have any special characters in the path of the GH file? Spaces were also a problem once. So you could also check this.
Hi @anna_kiwi3d sorry it’s been quite a while and I never answered your previous question regarding special characters in the path. I’m still unable to run Kiwi3d because carat.exe isn’t found.
There are no special characters, I’m simply trying to run the 5pt sail .gh example which doesn’t have any spaces in the file path:
@anna_kiwi3d I was able to resolve the issue by moving the files. The current rhi puts the contents into a child folder under the plugin folder 0.1.0.0 , by moving these one directory up to: C:\Users\username\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\TeDAsharp (ce983e9d-72de-4a79-8832-7c374e6e26de)
the issue was resolved.
