I’m using multiple .rvb script files and trying to ensure that my script for common functions and subs is loaded when starting other scripts.
Since there is no “include” function in Rhinoscript I’m trying to use Dale’s example from here
' Subroutine: Include
' Purpose: Includes, or loads, other RhinoScript files
' Argument: A script file name to include
' Example: Call Include("C:\Scripts\MyScriptFile.rvb")
Sub Include(strScriptName)
Dim objFSO, objFile
Set objFSO = CreateObject("Scripting.FileSystemObject")
Set objFile = objFSO.OpenTextFile(strScriptName)
ExecuteGlobal objFile.ReadAll()
objFile.Close
End Sub
My include script is as follows but it generates a “Cannot use parentheses when calling a Sub” error at the beginning of the “ExecuteGlobal” code line:
Function IncludeAtaraxiaScripts()
'Test Ataraxia Scripts Loaded
If Not Rhino.IsCommand("AtaraxiaScriptsLoaded") Then
Rhino.Print "BodyCuts:IncludeAtaraxiaScripts"
'Load Ataraxia Scripts
Dim strFilePath
strFilePath = Rhino.FindFile(sstrAtaraxiaScripts)
Dim objFileSystemObject
Set objFileSystemObject = CreateObject("Scripting.FileSystemObject")
Dim objScriptFile
Set objScriptFile = objFileSystemObject.OpenTextFile(strFilePath)
ExecuteGlobal objScriptFile.ReadAll()
objScriptFile.Close
If Not AtaraxiaScriptsLoaded Then
'Return Error
Rhino.Print sstrAtaraxiaScripts & " failed to load."
IncludeAtaraxiaScripts = False
Exit Function
End If
Rhino.Print "IncludeAtaraxiaScripts Done." : Rhino.Print
End If
'Return Success
IncludeAtaraxiaScripts = True
End Function
I’m hoping someone might be able to point me in the right direction
