Solved: Snaps but can't confirm command
As you see from the image I encountered several times the same thing, I would be able to object snap but can’t execute/Enter the command which is move here.
Is this a bug/my maybe buggy settings or is this a known issue or is this meant to be and I do not realize why.
Thank you for your help
Restarting Rhino resolved the issue. Thanks
PS: is there any way to delete posts, like this, which are obsolete. Thanks
Tap/click on the … symbol at the bottom right of your post. Click on the tras can symbol.
@davidcockey I mean the whole entry not the reply - seems like I can’t delete the first post of this entry. Thanks
You can check as solved or edit the title.
@david thank you will do so
