I have a Master Parts File which contains all of my parts for a project…
When I export a part from the Master Parts File, the file size is 30 MB.
If I export the exact same part from a brand new file, the file size is around 625kb.
I’ll hazard a guess that you have some bigger textures in the master file and that they’re ALL getting exported with each part (which is a bug). Just a guess, but I’ve seen similar things happen.
Thank you both…these suggestions helped to fix the issue in addition to the solution below…
After speaking with Rhino tech support, i was told that it is a bug and the number of material multiplies to such degree it is overwhelming. Removing all the plugin data will solve this:
SOLUTION: type “-Export” (MUST use the dash) into the command line; SavePluginData=No…this shrunk the files from 30 MB to under 1 MB!
