Solved: Index out of range
Created my first Hops-script.
Is there a way to trouble shoot were the error comes from (index out of range)?
If I simply copy my hops script and connect the wires, it works as intended.
Or has it something to do with the rhino compute server that reports Max concurrent requests = -1
This is the different results I get.
The lower part is the intended result,
the upper part shows the output when doing the same trough hops.
I should probably start with something simpler, the Hello world hops worked great.
But if someone has some input of what might be wrong, please let me know.
Attaching the gh-file with internalised geometry
hop_example.gh (36.3 KB)
It’s List Item that doesn’t work for med through hops.
I’m taking the first item from every branch, but when doing it through hops I guess it takes the first 3 items from the first branch.
listItem
ListItem.gh (2.8 KB)
Hej Lars -
You need to allow more than 1 for the “At most” setting:
Note: using a “RH_OUT” group is the old way of working with Hops. You can use the Context Bake component.
Thank you Wim.
It’s been a bit confusing reading old and new threads and trying to understand how it actually works now.
