SOLVED in 7.1: COPY use last distance prevents ENTER to end command
If I use COPY and Use Last Distance then the only thing that ends the command is ESC.
Please fix
Yeah, this has been reported and I thought it was fixed already in 7.1…
https://mcneel.myjetbrains.com/youtrack/issue/RH-58758
Ok, saw v7 upgradet to 7.1 as I closed it. Will check later!
EDIT: Yes, this is fixed in 7.1, thanks Mitch!
