Hey pros,
I am trying to offset a closed curve until it is filled in. I have hit a bug I can’t see. I commented the script so it should expain the process. if anyone feels like taking a look, I would really appreciate it.
The errors I see it that I pass an ID that can not be converted to a curve. I looked to see if I deleted a curve that was added to the list that gets passed back into the loop, but I can find anywhere that happens. I am stumped. rs.IsObject() doesn’t seem to catch it?
The problem is to offset the closed curve and capture all possible “islands” that can happen. Otherwise it’s an easy recursive loop. I found if it offset from multiple locations around he curve I will find the islands. Try for a result that looks like this. Loops through multiple starting curves.
thanks folks - Guy
Offset Fill Closed Curves.py (5.4 KB)
