[SOLVED] Best way to make this shape?
Hey folks,
I need to build this shape but I wonder if this is the best way to do it, because it creates a polysurface.
The method I used to create it was the Sweep2, using these curves:
Would there be a better way of making this shape?
Cheers!
EDIT: After rebuilding the curves, Rhino now created a single surface, which is what I wanted.
Are you sure the rail curves are not polycurves?
An alternate approach would be to do a one rail sweep of one of the side curves around the closed end curve.
I see you you found your own solution, but I’ll post this reply anyway for future reference by others.
