Solution exception:Index was out of range
“Solution exception:Index was out of range. Must be non-negative and less than the size of the collection. (Parameter ‘index’)”
When I start to create gene type output, this problem will arise. Is it because there are too many genes? Because multiple genomes involve more than 500 genes.
I used the Boolean value of the presence or absence of each block as the data of the gene pool (0 or 1). I just started learning wallacei. Is it because there are too many genes that it cannot be exported?
This problem occurs because I can export 25 types normally in another project, but even one item in this project cannot be exported.
according to the image you uploaded, the phenotype input appears to be empty. You can have as many gene as you want. the issue does not relate to the gene count.
grateful! It seems to have been resolved now!
Thank you very much!!
