I don’t see that with my simple GH definition here even at X 500,000 | Y 500,000 | Z 10,000… Or even with Z=500,000. The frames stretch without a problem.
ok, @Helvetosaur those small deviations are the horror! In some situations curves in Rhino seem to be planar, PlanarSrf works well, generating surfaces… still, when imported into Revit they become a problem.
Look, I have to write another dodgy script in order to planarize those programmatically.
#Replace all Z coordinates of a polyline with the Z of start point)
curves = rs.GetObjects(message=None, filter=4, group=True, preselect=True, select=False, objects=None, minimum_count=1, maximum_count=0, custom_filter=None)
for curve in curves:
points = rs.CurvePoints(curve)
startpoint = points[0]
startpointZ = startpoint[2]
curves_explode = rs.ExplodeCurves (curve)
newsegments =[]
for curve_explode in curves_explode:
points = rs.CurveEditPoints(curve_explode)
new_crv_points=[]
for point in points:
newpoint = point[0],point[1],startpoint[2]
new_crv_points.append(newpoint)
if rs.IsArc(curve_explode):
arcmidpoint = rs.ArcMidPoint(curve_explode)
arcstart = rs.CurveStartPoint(curve_explode)
arcend = rs.CurveEndPoint(curve_explode)
newarc = rs.AddArc3Pt(arcstart, arcend, arcmidpoint)
newsegments.append(newarc)
else:
newpoly = rs.AddPolyline(new_crv_points)
newsegments.append(newpoly)
rs.JoinCurves(newsegments,delete_input=True)
rs.DeleteObjects(curves_explode)
#print startpointZ
rs.DeleteObjects(curves)
I honestly think that this problem should be fixed somehow in R8, Is there anything planned?
I don’t think your script needs to be nearly that complicated.
"""Flatten curves to a plane parallel to World XY going thru the Z coordinate
of the curves' start point"""
def PlanarizeCrvsInZ():
msg="Select curves to planarize in Z"
crvs = rs.GetObjects(msg,4,True,True)
if not crvs: return
rs.EnableRedraw(False)
for crv in crvs:
plane=rs.WorldXYPlane()
plane.Origin=rs.CurveStartPoint(crv)
xform=rs.XformPlanarProjection(plane)
rs.TransformObject(crv,xform)
PlanarizeCrvsInZ()
Well most architecture is drawn in millimeters and if you have a 200meter tower or a cluster of buildings it is enough to end up in the twilight zone of digits…
Errors in Rhino are very common while moving solid points or edges at this scale, boolean operations also suffer.
Fixing 10- 20 errors per day is common practice. But most rhino users are skilled enough to fix or bypass those issues quickly.
I’m stressing it also because i see some push and pull modelling in R8 under development.
Well, I always say GIGO… no, not Grasshopper In, Grasshopper Out, but rather the original Garbage In, Garbage Out… I would be looking as to WHY your GH definition is producing this kind of problem, rather than trying to put a band-aid on the result…
Don’t buy it… goes back to GIGO… Geometry is as good as you (the operator/programmer) make it. Grasshopper will create geometry as accurate as native Rhino commands do if you set it up correctly, after all, it’s using the same geometric functions underneath.
Don’t agree… Fix-my-digits tool would be a life saver. After all, we do have Analysis section; Fix Meshes section…
Second, In some situations it might be user fault but it might very well be Rhino fault… as you work, you never know… after 50-70 design variations… nobody knows.
Oh, and third… this “far away from origin” excuse is quite lame…
Oh, and how can I forget, this variation of my model has 850 panels like the one I show above Imagine editing the “gigo”
