Solid Union Two Lists of Breps Together
I am trying to union one list of breps to another (ie. item 1 with item 1, item 2 with item 2, etc), but in order to use Solid Union, I have to merge the two lists together, and the output is just all the breps in list 1 unioned together with each other instead of with the items in the next list. When I go through the list from the Merge with List Item, the breps appear together in the order I want them to be unioned… How might I go about achieving this?
parameterized arch.3dm (2.6 MB)
parameterized arch.gh (99.5 KB)
Please post your file. It’ll be easier to help you.
Posted
parameterized arch_re.gh (96.9 KB)
Thank you for working on this problem, but I am having an issue with the Solid Union, not the Solid Difference. I am trying to combine each diamond with the block directly below it.
I have determined the solution. If you are experiencing a similar issue, let me know and I shall share
